BT.com
Wishlist
Peerless-AV SmartMount Universal Tilt Wall Mount for 32" to 50" Displays
Peerless-AV SmartMount Universal...
£62.31
More than 50 in stock
£62.31
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for medium/large LCD screens, the SmartMount ST640P tilting mount allows you to mount your LCD screen quickly and easily. The tilt function allows you to angle the screen forward or back for an enhanced viewing angle.
Peerless SmartMount Universal Tilt Wall Mount ST640P - mounting kit
Mounting kit - wall-mountable
Mounting Components
Bracket, tilt wall plate, security fasteners
56.2 cm x 47 cm x 14.5 cm
4.22 kg
Recommended Use
LCD display
Recommended Display Size
32"-60"
Flat Panel Mount Interface
400 x 400 mm
Max Mounting Pattern Size
458 x 449 mm
Max Load Weight
68 kg
5 years warranty
56.2 cm
47 cm
14.5 cm
4.22 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
400 x 400 mm
458 x 449 mm
32"-60"
Max Load Weight
68 kg
Limited warranty - 5 years
Scroll to top
