BT.com
Wishlist
Peerless-AV SmartMount Universal Tilt Wall Mount
for 10" to 29" Displays
Peerless-AV SmartMount Universal...
£23.37
Peerless-AV SmartMount Universal Tilt Wall Mount for 10" to 29" Displays
7 in stock
£23.37
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for small LCD screens, the SmartMount ST630P tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless SmartMount Universal Tilt Wall Mount ST630P - wall mount
Wall mount - wall-mountable
15.9 cm x 15.9 cm x 3.8 cm
Adjustments
Tilt
1 kg
Recommended Use
LCD display
Recommended Display Size
10"-29"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.3 kg
5 years warranty
15.9 cm
15.9 cm
3.8 cm
1 kg
AV Furniture
Wall mount
Mounting Components
Adapter plate, tilt wall mount
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
10"-29"
Adjustments
Tilt
Max Load Weight
36.3 kg
Scratch-resistant
Limited warranty - 5 years
Scroll to top
