BT.com
Wishlist
Peerless-AV SmartMount Universal Pivot Wall Mount For 10"- 29" Displays
Peerless-AV SmartMount Universal...
£44.86
3 in stock
£44.86
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for small LCD screens, the SmartMount SP730P pivoting wall mount gives you a wide range of screen adjustment to obtain a better viewing angle. The SP730P allows you to tilt your screen forward or back, pan left or right and even extend your flat panel screen away from the wall.
Peerless SmartMount Pivot Wall Mount SP730P - wall mount (Tilt & Swivel)
Wall mount (Tilt & Swivel)
80 g
Recommended Use
LCD display
Recommended Display Size
10"-29"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Anodised aluminium
5 years warranty
80 g
Material
Anodised aluminium
AV Furniture
Wall mount
Mounting Components
Pivot wall mount
Design
Tilt & Swivel
Recommended Use
LCD display
10"-29"
Max Load Weight
11.3 kg
Limited warranty - 5 years
Scroll to top
