BT.com
Wishlist
Peerless-AV SmartMount Universal Flat Wall Mount for 60" to 98" Displays
Peerless-AV SmartMount Universal...
£132.45
16 in stock
£132.45
Add to wishlist
Delivery
Standard 1-3 working days
Peerless-AV’s SmartMount® Universal Flat Wall Mount delivers an ultra-slim profile designed to hold large displays up to 350lb. Installation and maintenance are made easy with the SF680’s robust feature set. Auto-latching adaptor rails automatically secure the display without the use of a tool. The mount’s built-in kickstand holds the display safely from the wall during cable routing, while the open wall plate allows for increased electrical and cable management options. Horizontal and vertical display adjustment allow for quick fine-tuning of the mounted display.
Peerless SmartMount Universal Flat Wall Mount SF680P - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
116.2 cm x 5 cm x 76.8 cm
6.1 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
60"-95"
Flat Panel Mount Interface
1100 x 650 mm
Max Load Weight
158.8 kg
Material
Steel, fused epoxy
5 years warranty
116.2 cm
5 cm
76.8 cm
6.1 kg
Material
Steel, fused epoxy
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
1100 x 650 mm
60"-95"
Max Load Weight
158.8 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Scroll to top
