BT.com
Wishlist
Peerless-AV SmartMount Universal Flat Wall Mount for 39" to 80" Displays
Peerless-AV SmartMount Universal...
£77.89
More than 50 in stock
£77.89
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for extra large LCD and plasma screens, the SmartMount SF660P flat-to-wall mount allows you to mount your LCD/plasma screen quickly and easily.
Peerless SmartMount Universal Flat Wall Mount SF660P - mounting kit
Mounting kit - wall-mountable
Mounting Components
Wall plate, bracket
86.7 cm x 2.8 cm x 45.7 cm
4.2 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-80"
Flat Panel Mount Interface
Up to 824 x 405 mm
Max Load Weight
90.7 kg
5 years warranty
86.7 cm
2.8 cm
45.7 cm
4.2 kg
AV Furniture
Mounting kit
Mounting Components
Wall plate, bracket
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
Up to 824 x 405 mm
39"-80"
Max Load Weight
90.7 kg
Limited warranty - 5 years
Scroll to top
