BT.com
Wishlist
Peerless-AV SmartMount Universal Flat Wall Mount for 37" to 75" Displays
Peerless-AV SmartMount Universal...
£56.55
Hurry, only 1 left in stock!
£56.55
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Ideally suited for large LCD and Plasma screens, the SmartMount SF650P flat-to-wall mount allows you to mount your LCD/Plasma screen quickly and easily. The low profile design holds the screen only 43mm away from the wall.
Peerless SmartMount Universal Flat Wall Mount SF650P - mounting kit
Mounting kit
Mounting Components
Wall plate, deep bracket
78.1 cm x 4.3 cm x 45.7 cm
3.5 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-75"
Flat Panel Mount Interface
Up to 742 x 405 mm
Max Load Weight
79 kg
Material
Hardened steel, fused epoxy
78.1 cm
4.3 cm
45.7 cm
3.5 kg
Material
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
Up to 742 x 405 mm
39"-75"
Max Load Weight
79 kg
Sorted-For-You, scratch-resistant
Scroll to top
