BT.com
Wishlist
Peerless-AV SmartMount Universal Flat Wall Mount for 32" to 50" Displays
Peerless-AV SmartMount Universal...
£42.84
More than 50 in stock
£42.84
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for medium/large LCD screens, the SmartMount SF640P flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 30mm away from the wall.
Peerless SmartMount Universal Flat Wall Mount SF640P - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket
48.3 cm x 3 cm x 34.8 cm
2.2 kg
Recommended Use
LCD display
Recommended Display Size
32"-50"
Flat Panel Mount Interface
400 x 400 mm
Max Load Weight
68 kg
5 years warranty
48.3 cm
3 cm
34.8 cm
2.2 kg
AV Furniture
Mounting kit
Mounting Components
Wall plate, bracket
Recommended Use
LCD display
400 x 400 mm
32"-50"
Max Load Weight
68 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Scroll to top
