BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Peerless-AV SmartMount Universal Flat Wall Mount for 22" to 40" Displays
Delivery
Standard 3-5 working days
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Peerless SF632P universal flat wall mount for LCDs 22-40-inch. The ultra-slim wall plate keeps the screen close to the wall for a very discreet installation that is perfect for digital signage, POS stations, or office applications.
For a quick and easy installation it may be mounted to a single wood stud, concrete or cinder block. Mounts to metal stud using accessory metal stud fasteners. Compatible with VESA 75mm, 100mm, 200mm x 100mm, and 200mm x 200mm mounting hole patterns.
Scroll to top
