BT.com
Wishlist
Peerless-AV SmartMount Pivot Wall Mount
For 32" to 50" Displays
Peerless-AV SmartMount Pivot Wall...
£132.42
Peerless-AV SmartMount Pivot Wall Mount For 32" to 50" Displays
£132.42
Add to wishlist
Delivery
Standard Due date unavailable
Supporting screens up to 46" the SP746PU mount provides pivoting functionality for the viewing angle adjustment when full articulation is not required. This user-friendly and easy to install mount delivers one touch side-to-side swivel and tilting functionality that is complemented by its lightweight construction and intuitive three step installation process. Adding to its pivot functionality is the mount's clean aesthetic, contributed to by its cable management system that easily organizes and routes cables, focusing all the attention on the screen.
Peerless SmartMount Pivot Wall Mount SP746PU - wall mount
Wall mount
47.6 cm 43.2 cm
Adjustable Depth
9.5-31.9 cm
Adjustments
Tilt
3.28 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
22"-50"
Flat Panel Mount Interface
400 x 400 mm
Max Load Weight
36 kg
Material
Fused epoxy
Gloss black
5 years warranty
47.6 cm
43.2 cm
Adjustable Depth
9.5-31.9 cm
3.28 kg
Material
Fused epoxy
Gloss black
AV Furniture
Wall mount
Mounting Components
Pivot wall mount
Recommended Use
LCD / plasma panel
400 x 400 mm
Cable Management
Cable Management System (CMS)
22"-50"
Adjustments
Tilt
Max Load Weight
36 kg
Adjustable depth, scratch-resistant, swivel adjustment
Limited warranty - 5 years
Scroll to top
