BT.com
Wishlist
Peerless-AV SmartMount Flat Panel Trolley 55"- 98"
Peerless-AV SmartMount Flat Panel...
£676.83
Hurry, only 3 left in stock!
£676.83
Add to wishlist
Delivery
Standard 1-3 working days
The SR598 Flat Panel TV Cart has been redesigned to include all of the features you may need, making it perfect for any application. Mobility, appealing design, display height adjustment, pre-assembled base and UL certification ensure quick assembly while providing a ridged, but attractive, structure that fits into any decor. The 4" castors make it easy to move from room to room while the UL certification ensures you that it can be done with safety in mind.
Peerless-AV SmartMount SR598 - cart
Cart
116.9 cm x 73.7 cm x 173.6 cm
Tilt
-5°
40.5 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
55"-98"
Flat Panel Mount Interface
Up to 900 x 600 mm, from 200 x 200 mm
Max Mounting Pattern Size
981 x 608 mm
Max Load Weight
102.27 kg
Material
Aluminium
Black powder coat
Wheels Qty
4
5 years warranty
116.9 cm
73.7 cm
173.6 cm
40.5 kg
Material
Aluminium
Black powder coat
AV Furniture
Cart
Recommended Use
LCD / plasma panel
981 x 608 mm
Cable Management
Integrated cable management
55"-98"
Tilt
-5°
Max Load Weight
102.27 kg
Wheels Qty
4
Locking casters, swivel adjustment, swivel casters, security hardware
Limited warranty - 5 years
Scroll to top
