BT.com
Wishlist
Peerless-AV SmartMount Articulating Wall Mount for 39"-75" Displays
Peerless-AV SmartMount Articulating...
£292.20
£292.20
Add to wishlist
Delivery
Standard 1-3 working days
Ideally suited for extra large LCD and plasma screens, the SmartMount SA761PU articulating wall mount gives you the widest range of screen adjustment to obtain the best possible viewing angle. Tilt back or forward, pan left or right, even extend your flat panel screen away from the wall - the SA761PU has it all.
Peerless Universal Full-Motion Plus Wall Mount SA761PU - wall mount
Wall mount
72.8 cm x 11.3 cm x 45.7 cm
Adjustable Depth
11.3-70 cm
Adjustments
Tilt
18 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-75"
Flat Panel Mount Interface
600 x 400 mm
Max Load Weight
56.7 kg
Material
Fused epoxy
Gloss black
5 years warranty
72.8 cm
11.3 cm
45.7 cm
Adjustable Depth
11.3-70 cm
18 kg
Material
Fused epoxy
Gloss black
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
600 x 400 mm
Cable Management
Cable Management System (CMS)
39"-75"
Adjustments
Tilt
Max Load Weight
56.7 kg
Horizontal or vertical screen orientation, swivel base, adjustable depth, scratch-resistant, swivel adjustment
Limited warranty - 5 years
Scroll to top
