BT.com
Wishlist
Peerless-AV SmartMount Articulating Wall Mount For 10"-29" Displays
Peerless-AV SmartMount Articulating...
£59.82
10 in stock
£59.82
Add to wishlist
Delivery
Standard 3-5 working days
From any angle, this wall arm mount reflects remarkable form and function. Extending the display up to 16" from the wall and allowing for a full 180° of side-to-side motion for viewing in any part of the room. Fine-tuning of the installation is simple with its side-to-side display leveling features that help achieve installation perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a cable management system, centering the TV on the wall when retracted and organizing and protecting the cables at all times. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Arm Mounts.
Peerless Full-Motion Plus Wall Mount SA730P - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Articulating arm
Recommended Use
LCD TV
Recommended Display Size
10"-29"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
AV Furniture
Mounting kit
Mounting Components
Articulating arm
Design
Tilt & Swivel
Recommended Use
LCD TV
10"-29"
Scroll to top
