BT.com
Wishlist
Peerless-AV SmartMount Articulating Wall Arm For 32"-50" Displays
Peerless-AV SmartMount Articulating...
£155.80
Hurry, only 3 left in stock!
£155.80
Add to wishlist
Delivery
Standard 1-3 working days
From any angle, this Full-Motion Plus Wall Mount reflects remarkable form and function. This noticeably smaller and lighter weight universal, two-link Full-Motion Plus Wall Mount will accommodate a wide range of displays, delivering ultimate performance and maximum support with a minimal footprint. This Full-Motion Plus Wall Mount's design features a fold-flat-and-center design that centers the display on the wall plate when the mount is in its closed position. It provides a clean aesthetic with its cable management system that easily hides, organizes and routes cables, focusing all the attention on the display. With an exceptional extension up to 20.18" (513mm) from the wall and a full 180° of side-to-side motion, this mount provides virtually unlimited viewing possibilities. Installation is made simple with post installation fine-tuning that allows for display alignment adjustments, ensuring the display is level even if the mounting surface is not perfect. Designed and built in the USA.
Peerless Full-Motion Plus Wall Mount SA746PU - mounting kit
Mounting kit
Mounting Components
Wall plate, articulating arm
47.6 cm 43.2 cm
Adjustable Depth
11-53.1 cm
Adjustments
Tilt
4 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
22"-50"
Flat Panel Mount Interface
400 x 400 mm
Max Load Weight
36 kg
Material
Fused epoxy
Gloss black
5 years warranty
47.6 cm
43.2 cm
Adjustable Depth
11-53.1 cm
4 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
400 x 400 mm
Cable Management
Cable Management System (CMS)
22"-50"
Adjustments
Tilt
Max Load Weight
36 kg
Adjustable depth, scratch-resistant
Limited warranty - 5 years
Scroll to top
