BT.com
Wishlist
Peerless-AV Slimline Ultra-Flat to Wall Mount in Black 68kg (15
Peerless-AV Slimline Ultra-Flat to...
£62.31
2 in stock
£62.31
Add to wishlist
Delivery
Standard 3-5 working days
Ultra Slim is the world's thinnest flat to wall mounting solution at less that 0.84cm - yes that's only 8.4mm! - making it almost invisible once installed. Designed for the next generation of super slim LCD panels this product is a step ahead of anything else available in the market. Own the most discrete wall mount ever developed with the Ultra Slim range from Peerless.
Peerless Slimline Universal Ultra-Thin Flat Wall Mount SUF640P - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
52.6 cm x 1 cm x 40.9 cm
1.52 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
37"-50"
Max Mounting Pattern Size
450 x 402 mm
Max Load Weight
68 kg
Material
Cold-rolled steel
High-gloss black
5 years warranty
52.6 cm
1 cm
40.9 cm
1.52 kg
Material
Cold-rolled steel
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
450 x 402 mm
37"-50"
Max Load Weight
68 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Scroll to top
