BT.com
Wishlist
Peerless-AV Rotational Mount I-Face (Requires Mount+ PLP Adaptor Plate)
Delivery
Standard Due date unavailable
Go from landscape to portrait with a simple pull of the spring-loaded lever, eliminating the need to remove the screen from the mount whenever the content orientation changes. In addition, the RMI1 enables a mounted screen to be easily rotated and set at 15-degree increments within 360 degrees. Ideal for standard or creative digital signage displays - landscape, portrait, waves, zigzag and 45-degree angle patterns - the possibilities are endless. The RMI1 is compatible with Peerless' selection of wall mounts, ceiling mounts, carts and stands.
Peerless Rotational Mount Interface RMI1 - mounting component
Mounting component - ceiling mountable, wall-mountable
Mounting Components
Mount
32.9 cm x 2.4 cm x 18.8 cm
2.3 kg
Recommended Use
LCD display
Recommended Display Size
22" - 71"
Max Load Weight
79.5 kg
Material
Fused epoxy
5 years warranty
32.9 cm
2.4 cm
18.8 cm
2.3 kg
Material
Fused epoxy
AV Furniture
Mounting component
Mounting Components
Mount
Recommended Use
LCD display
Placing / Mounting
Ceiling mountable, wall-mountable
22" - 71"
Max Load Weight
79.5 kg
Rotating, tamper resistant adjustment screws, portrait to landscape movement, scratch-resistant, lockable
Limited warranty - 5 years
Scroll to top
