BT.com
Wishlist
Peerless-AV Quad Monitor Desktop Arm Mount up to 24"
Peerless-AV Quad Monitor Desktop...
£378.60
£378.60
Add to wishlist
Delivery
Standard Due date unavailable
The LCT620AQ-G Desktop Monitor Mount features four attractive height adjustable articulating arms that provide perfect ergonomics with optimum monitor positioning for virtually all users. The grommet mounting base provides limitless mounting options on any desktop or countertop surface between ½" to 2" (12 to 55mm) thick.
Peerless-AV LCT620AQ-G - mounting kit
Mounting kit
Mounting Components
4 articulating arms, desk grommet
Adjustments
Roll, tilt
17.3 kg
Recommended Use
4 LCD displays
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8.1 kg
Material
Aluminium
5 years warranty
17.3 kg
Material
Aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
4 LCD displays
Cable Management
Integrated cable management
Up to 24"
Adjustments
Roll, tilt
Max Load Weight
8.1 kg
Min Load Weight
3.8 kg
TAA Compliant
Adjustable height, pivot
Limited warranty - 5 years
Scroll to top
