BT.com
Wishlist
Peerless-AV PRSS Projector Mount for Projectors up to 22kg
Delivery
Standard Due date unavailable
The PRSS projector mount allows for independent pitch, roll and swivel alignment with two easily accessible adjustment points. Just set the mount to the desired position and secure it in place. It will hold its position even during projector maintenance. With its discreet, low-profile design the projector mount is perfect for flush mounting applications. With Peerless-AV PRSS projector mount, just set it and forget it.
Peerless PRSS PRSS-UNV-W - ceiling mount
Ceiling mount
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
2.14 kg
Recommended Use
Projector
Max Load Weight
22 kg
White powder coat
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
2.14 kg
White powder coat
Image Colour Disclaimer
The displayed product image may be a different colour
AV Furniture
Ceiling mount
Mounting Components
Ceiling mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Adjustments
Roll, yaw, tilt
Max Load Weight
22 kg
Quick release
Scroll to top
