BT.com
Wishlist
Peerless-AV PRSS Projector Mount for Projectors up to 22kg
Peerless-AV PRSS Projector Mount...
£84.12
7 in stock
£84.12
Add to wishlist
Delivery
Standard 3-5 working days
The PRSS projector mount offers one of the fastest and easiest installations available in the market. It allows for independent pitch, roll and swivel alignment with two easily accessible adjustment points. Just set the mount to the desired position and secure it in place. It will hold its position even during projector maintenance. With its discreet, low-profile design the projector mount is perfect for flush mounting applications.
Peerless PRSS PRSS-UNV - ceiling mount
Ceiling mount
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
Tilt
2.14 kg
Recommended Use
Projector
Max Load Weight
22 kg
Black powder coat
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
2.14 kg
Black powder coat
AV Furniture
Ceiling mount
Mounting Components
Ceiling mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Tilt
Adjustments
Roll, yaw
Max Load Weight
22 kg
Quick release
Scroll to top
