BT.com
Wishlist
Peerless-AV Projector Wall Arm (362mm reach) up to 23kg - Black
Peerless-AV Projector Wall Arm...
£41.32
£41.32
Add to wishlist
Delivery
Standard Due date unavailable
The Projector Wall Arm offers the same adjustability as the ceiling mount while allowing the projector to be attached to the wall. This low-profile mount is designed with security, functionality, aesthetics, and ease of installation in mind. Compatible with most Peerless Projector Mounts.
Peerless Projector Wall Arm PWA-14 - mounting component
Mounting component - wall-mountable
Mounting Components
Wall arm
1.5 kg
Recommended Use
Projector
Max Load Weight
22.7 kg
Vector Pro PJC 100
1.5 kg
AV Furniture
Mounting component
Mounting Components
Wall arm
Recommended Use
Projector
Placing / Mounting
Wall-mountable
Max Load Weight
22.7 kg
Peerless Vector Pro PJC 100
Scroll to top
