BT.com
Wishlist
Peerless-AV PRGS Projector Mount for Projectors up to 22kg
Peerless-AV PRGS Projector Mount...
£106.00
Hurry, only 1 left in stock!
£106.00
Add to wishlist
Delivery
Standard 1-3 working days
The PRGS series projector mount is simplifying the way image alignment is done. The precision gear design allows exact tilt and roll image positioning by either simply turning two adjustment knobs with a Phillips screw driver, or using the tool-less option by extending the knobs to adjust by hand. Just set the precision gear to the desired position to secure it in place - it will hold its position better than the competition, even during projector maintenance. With Peerless-AV's PRGS series projector mount, just set it and forget it. No more adjustment screws. No more micro adjustments. No more hassles.
Peerless PRGS-UNV - mounting kit
Mounting kit - ceiling mountable
Mounting Components
Universal mount
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
Adjustments
Yaw, tilt
700 g
Recommended Use
Projector
Max Load Weight
22 kg
Black powder coat
5 years warranty
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
700 g
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Universal mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
Adjustments
Yaw, tilt
Max Load Weight
22 kg
Swivel adjustment
Limited warranty - 5 years
Scroll to top
