BT.com
Wishlist
Peerless-AV Portable Video Wall Cart 3x2 for 46-55" Displays
Peerless-AV Portable Video Wall...
£2,991.60
£2,991.60
Add to wishlist
Delivery
Standard Due date unavailable
Peerless-AV takes video wall carts to a high level of innovation. With this modular design, a video wall cart configuration can be built with just a single SKU. This Modular Video Wall Cart offers an 8-point micro-adjustment to create a seamless alignment without the need of tools. With a five-inch lockable caster, the cart becomes secure for safe and easy movement over various flooring surfaces. Designed for a quick set-up and tear down, the cart features a quick-connect latch for adaptors, allowing automatic engagement with mounting rails. Media storage and cable management create a sleek appearance for any application setting. With an overall weight and shipping cost reduction, this Portable Video Wall Cart makes this the ultimate video wall cart solution.
Peerless-AV Portable Video Wall DS-C555-3X2 - cart
Cart
Recommended Use
3x2 video wall
Recommended Display Size
46"-55"
Flat Panel Mount Interface
200 x 200 mm, up to 600 x 400 mm
Max Load Weight
272 kg
Black, powder coat
Black, powder coat
AV Furniture
Cart
Recommended Use
3x2 video wall
Cable Management
Integrated cable management
46"-55"
Max Load Weight
272 kg
Wheel Diameter
12.7 cm
Locking casters
Scroll to top
