BT.com
Wishlist
Peerless-AV Peerless Universal Flat Wall Mount for 32" to 40" Displays
Peerless-AV Peerless Universal Flat...
£38.94
£38.94
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Ideally suited for medium/large LCD screens, the Paramount PF640 flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 30mm away from the wall.
Peerless PARAMOUNT Universal Flat Wall Mount PF640 - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
48.9 cm x 3 cm x 34.9 cm
2 kg
Recommended Use
LCD display
Recommended Display Size
32"-40"
Flat Panel Mount Interface
400 x 300 mm
Max Load Weight
45 kg
Material
Fused epoxy
Gloss black
5 years warranty
48.9 cm
3 cm
34.9 cm
2 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
400 x 300 mm
32"-40"
Max Load Weight
45 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Scroll to top
