BT.com
Wishlist
Peerless-AV Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV-W (White)
Peerless-AV Peerless PRG Precision...
£116.86
£116.86
Add to wishlist
Delivery
Standard 1-3 working days
Peerless' PRG Precision Gear Projector Mount is changing the way image alignment is carried out. The patent-pending precision gear design provides exact tilt and roll image positioning with a simple turn of a knob. Once the precision gear is set to the desired position it stays securely in place. It will not shift during projector maintenance, bulb replacement, and will not loosen or change alignment due to vibration, accidental bumping etc. With Peerless' PRG Precision Gear Projector Mount the installer sets it and forgets it.
Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV-W - mounting component (Tilt & Swivel)
Mounting component (Tilt & Swivel)
Mounting Components
Ceiling mount, spider arms
1.3 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Aluminium alloy
White
1.3 kg
Material
Aluminium alloy
White
AV Furniture
Mounting component
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Max Load Weight
22.6 kg
Quick release, scratch-resistant
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Damaged stock - Item is new but has packaging damage
Ref: 7MTD 037414
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£90.50
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
