BT.com
Wishlist
Peerless-AV Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV (Black)
Peerless-AV Peerless PRG Precision...
£116.86
12 in stock
£116.86
Add to wishlist
Delivery
Standard 1-3 working days
Peerless' PRG Precision Gear Projector Mount is changing the way image alignment is carried out. The patent-pending precision gear design provides exact tilt and roll image positioning with a simple turn of a knob. Once the precision gear is set to the desired position it stays securely in place. It will not shift during projector maintenance, bulb replacement, and will not loosen or change alignment due to vibration, accidental bumping etc. With Peerless' PRG Precision Gear Projector Mount the installer sets it and forgets it.
Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV - mounting component (Tilt & Swivel)
Mounting component (Tilt & Swivel)
Mounting Components
Ceiling mount, spider arms
1.3 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Aluminium alloy
1.3 kg
Material
Aluminium alloy
AV Furniture
Mounting component
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Max Load Weight
22.6 kg
Quick release, scratch-resistant
Scroll to top
