Click to visit BT.com
BT.com
Wishlist
Peerless-AV Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable ExtensionPPA-S-mounting kit (Silver)
Quicklinx: 7MTKWS00
Mfr#: PPA-S
Type: [N/A]
Brightness: [N/A]
Contrast Ratio: [N/A]
Portability: [N/A]
Resolution: [N/A]
£73.86
Allows a projector to be ceiling or wall mounted. Adjustable extension - 324-452mm (ceiling), 253-357mm (wall).
Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable Extension PPA-S - mounting kit ( Tilt & Swivel )
Mounting kit ( Tilt & Swivel )
Mounting Components
Extension column, ceiling plate, mounting adapter, horizontal adjuster
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
32.4-45.2 cm
1.4 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Cold-rolled steel
Silver
5 years warranty
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
32.4-45.2 cm
1.4 kg
Material
Cold-rolled steel
Silver
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Max Load Weight
22.6 kg
Scratch-resistant
5 years warranty
Service & Support Details
Limited warranty - 5 years
Peerless-AV Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable ExtensionPPA-S-mounting kit (Silver) Bundle deal on Peerless-AV Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable ExtensionPPA-S-mounting kit (Silver)
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£83.85
Type: [N/A]
Brightness: [N/A]
Portability: [N/A]
Resolution: [N/A]
Brand: Peerless-AV
Price Range Inc VAT: 50 - 100
