Peerless' Security Lockable Mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
Peerless Flat-to-Wall Security Locking Mount PFLP650 - wall mount
Wall mount
50.8 cm x 4.3 cm x 71.5 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
32" - 58"
Flat Panel Mount Interface
700 x 400 mm
Max Load Weight
79 kg
50.8 cm
4.3 cm
71.5 cm
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
700 x 400 mm
32" - 58"
Max Load Weight
79 kg
Lockable
