BT.com
Wishlist
Peerless-AV Paramount Flat Panel Ceiling Mount for 15-37" Displays
Peerless-AV Paramount Flat Panel...
£77.55
£77.55
Add to wishlist
Delivery
Standard Due date unavailable
No wall space? No problem. This VESA compliant LCD ceiling mount gets the TV up easily and offers an incredible range of viewing options. Installation is made simple with its one-, two-, three- design. Simply attach the ceiling plate, attach the adapter to the screen and hook-on the TV on to the mount - Done. This LCD TV mount delivers the ultimate in positioning options with its tilt and infinite swivel options for that ultimate flat panel viewing experience.
Peerless PARAMOUNT LCD Ceiling Mount PC932A - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, tilt bracket, mounting adapter
16.5 cm x 16.5 cm
Adjustable Height
24.8-35.3 cm
2 kg
Recommended Use
LCD TV
Recommended Display Size
15"-37"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Material
Cold-rolled steel
5 years warranty
16.5 cm
16.5 cm
Adjustable Height
24.8-35.3 cm
2 kg
Material
Cold-rolled steel
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
15"-37"
Scratch-resistant
Limited warranty - 5 years
Scroll to top
