BT.com
Wishlist
Peerless-AV Paramount Flat Panel Ceiling Mount for 15-24" Displays
Delivery
Standard Due date unavailable
No wall space? No problem. The ceiling is a great place to mount a flat panel when there is no wall available. Ceiling installation is made simple with PC930s one-, two-, three- design. Simply attach the ceiling plate, attach the adapter to the screen and hook-on the TV on to the mount - Done. This VESA compliant LCD mount delivers the ultimate in positioning options with its tilt and infinite swivel to achieve an ideal flat panel viewing experience.
Peerless PARAMOUNT LCD Ceiling Mount PC930B - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, tilt bracket, mounting adapter
16.5 cm x 16.5 cm
Adjustable Height
35-55.6 cm
1.7 kg
Recommended Use
LCD TV
Recommended Display Size
15"-24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Material
Cold-rolled steel
5 years warranty
16.5 cm
16.5 cm
Adjustable Height
35-55.6 cm
1.7 kg
Material
Cold-rolled steel
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
15"-24"
Scratch-resistant
Limited warranty - 5 years
Scroll to top
