BT.com
Wishlist
Peerless-AV Paramount Ceiling/Wall Projector Mount with Adjustable Extension PPA-W
Peerless-AV Paramount Ceiling/Wall...
£76.17
2 in stock
£76.17
Add to wishlist
Delivery
Standard 3-5 working days
Allows a projector to be ceiling or wall mounted. Adjustable extension - 324-452mm (ceiling), 253-357mm (wall).
Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable Extension PPA-W - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, mounting adapter, horizontal adjuster
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
32.4-45.2 cm
1.4 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Cold-rolled steel
White
5 years warranty
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
32.4-45.2 cm
1.4 kg
Material
Cold-rolled steel
White
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Max Load Weight
22.6 kg
Scratch-resistant
Limited warranty - 5 years
Scroll to top
