BT.com
Wishlist
Peerless-AV Modular Series PRSS Projector Mount Ceiling Kit
Peerless-AV Modular Series PRSS...
£169.47
£169.47
Add to wishlist
Delivery
Standard 1-3 working days
The Peerless-AV modular mount line includes a small and easily manageable number of skus, yet provides a full range of options that can fulfill a vast majority of end-user requirements. Universal components make it quick and easy to design and configure the perfect custom projector mounting solution, ideal for any application. Designed around a 2" (50 mm) diameter extension pole, the line is ideal for projects as well as upgrading existing installations.
Peerless MOD-PRSSKIT - mounting kit
Mounting kit
Mounting Components
Ceiling plate, extension pole, universal adaptor
Tilt
Pan
360°
Recommended Use
Projector
Max Mounting Pattern Size
448 x 448 mm
Max Load Weight
22 kg
Black chrome
5 years warranty
Black chrome
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
448 x 448 mm
Cable Management
Integrated cable management
Tilt
Pan
360°
Adjustments
Roll
Max Load Weight
22 kg
Quick release, swivel adjustment
Dimensions & Weight Details
Dimensions
Column - height: 1 m
Limited warranty - 5 years
Scroll to top
