BT.com
Wishlist
Peerless-AV Modular Series PRSS Projector Mount Ceiling Kit
Peerless-AV Modular Series PRSS...
£160.26
£160.26
Add to wishlist
Delivery
Standard 1-3 working days
The Peerless-AV modular mount line includes a small and easily manageable number of sku's, yet provides a full range of options that can fulfill a vast majority of end-user requirements. Universal components make it quick and easy to design and configure the perfect custom projector mounting solution, ideal for any application. Designed around a 2" (50 mm) diameter extension pole, the line is ideal for projects as well as upgrading existing installations. The MOD-PRSSKIT100 ceiling mount kits include all of the components required to mount a projector from the ceiling. As part of the Peerless-AV modular series, it can be expanded with additional modular accessories to accommodate virtually any custom configuration.
Peerless PRSS MOD-PRSSKIT100 - mounting kit
Mounting kit
Mounting Components
Ceiling plate, extension pole, spider adapter
Adjustable Width
11.8-44.8 cm
Adjustable Depth
22.5-44.8 cm
Adjustable Height
109.8-112.3 cm
Adjustments
Roll, pitch, yaw
3.2 kg
Recommended Use
Projector
Max Load Weight
22 kg
Chrome, black powder coat
5 years warranty
Adjustable Width
11.8-44.8 cm
Adjustable Depth
22.5-44.8 cm
Adjustable Height
109.8-112.3 cm
3.2 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
Cable Management
Integrated cable management
Adjustments
Roll, pitch, yaw
Max Load Weight
22 kg
Limited warranty - 5 years
Scroll to top
