BT.com
Wishlist
Peerless-AV Modular Series Dual-Pole Cosmetic Cover For Modular Series
Peerless-AV Modular Series...
£55.26
6 in stock
£55.26
Add to wishlist
Delivery
Standard 3-5 working days
Peerless-AV's Modular mount series fulfills multiple requirements with a limited number of components. The universality of the components allows you to configure your own perfect custom flat-panel display or projector mounting solution for any application. The Modular mount series was developed with the professional AV installer in mind with a 2" (50 mm) diameter support pole that can be easily cut to length on the job site making it ideal for new projects as well as for upgrading existing installations.
Peerless Modular Series MOD-ACF2 - mounting component
Mounting component - ceiling/floor mountable
Mounting Components
Plate cover
20.4 cm x 20.4 cm x 3.1 cm
450 g
Recommended Use
LCD / plasma / projector
Recommended Display Size
46"-90"
Max Load Weight
192 kg
Black powder coat
20.4 cm
20.4 cm
3.1 cm
450 g
Black powder coat
AV Furniture
Mounting component
Mounting Components
Plate cover
Recommended Use
Placing / Mounting
Ceiling/floor mountable
46"-90"
Max Load Weight
192 kg
Security screws, 2 x pole holes
Limited warranty - 5 years
Scroll to top
