BT.com
Wishlist
Peerless-AV Metal Shelf
£71.92
6 in stock
£71.92
Add to wishlist
Delivery
Standard 3-5 working days
The SmartMount Metal Shelf is designed to attach to the newly redesigned SmartMount SR Flat Panel cart and SS Flat Panel stand. The shelf provides a secure yet sleek surface for various AV equipment and accessories to create great viewing experience.
Peerless-AV SmartMount ACC-MS - mounting component
Mounting component
Mounting Components
Shelf
50.8 cm x 41.6 cm x 8.7 cm
5.91 kg
Recommended Use
AV System
Max Load Weight
4.55 kg
Material
Metal
Black powder coat
5 years warranty
50.8 cm
41.6 cm
8.7 cm
5.91 kg
Material
Metal
Black powder coat
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
AV System
Max Load Weight
4.55 kg
Quick release, scratch-resistant
Dimensions & Weight Details
RoHS
Limited warranty - 5 years
Scroll to top
