BT.com
Wishlist
Peerless-AV LCD Screen Single Arm 2-Link with Clamp & Grommet
Peerless-AV LCD Screen Single Arm...
£102.84
12 in stock
£102.84
Add to wishlist
Delivery
Standard 3-5 working days
Increase productivity by freeing up desk space with more efficient display positioning. The 620A series is a single display Full-Motion Plus Wall Mount, and includes a grommet and desktop clamp mount solution. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of a display by raising or lowering it 12.6", extending it up to 22", and tilting it forward and back. Furthermore, the LCT620A can pan and rotate for a comfortable portrait or landscape viewing.
Peerless 620A Series Desktop Mount LCT620A - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel) - table mount
Mounting Components
Articulating arm, desk clamp mount, grommet mount, column tube
Recommended Use
LCD display
Recommended Display Size
12"-30"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD display
Placing / Mounting
Table mount
Cable Management
Integrated cable management
12"-30"
Adjustable height, quick release, portrait to landscape movement
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Damaged stock - Item is new but has packaging damage.
Ref: 9Z35 035507
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£68.78
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
