BT.com
Wishlist
Peerless-AV LCD/Plasma Trolley with Metal Shelf 32" - 75" max
Peerless-AV LCD/Plasma Trolley with...
£466.05
£466.05
Add to wishlist
Delivery
Standard 1-3 working days
The SR560M Flat Panel TV Cart has been redesigned to include all of the features you may need, making it perfect for any application. Mobility, appealing design, display height adjustment, pre-assembled base and UL certification ensure quick assembly while providing a ridged, but attractive, structure that fits into any d├ęcor.
The 4" castors make it easy to move from room to room while the UL certification ensures you that it can be done with safety in mind.
Peerless SmartMount Universal Flat Panel TV Cart SR560M - cart
Cart
88.8 cm x 73.7 cm x 173.6 cm
Tilt
-5°
Rotation
360°
30 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-75"
Flat Panel Mount Interface
600 x 400 mm
Max Load Weight
68.2 kg
5 years warranty
88.8 cm
73.7 cm
173.6 cm
30 kg
AV Furniture
Cart
Recommended Use
LCD / plasma panel
600 x 400 mm
Shelf Qty
1
Cable Management
Integrated cable management
32"-75"
Tilt
-5°
Rotation
360°
Max Load Weight
68.2 kg
Swivel casters
Dimensions & Weight Details
RoHS, cULus
Limited warranty - 5 years
Scroll to top
