BT.com
Wishlist
Peerless-AV Large Flat Panel Tabletop Stand with Black Base
Peerless-AV Large Flat Panel...
£232.93
£232.93
Add to wishlist
Delivery
Standard Due date unavailable
This product is ideal for 32-50" LCD and plasma screens up to 68kg (150lbs).
Peerless PLT-BLK - mounting component
Mounting component
Mounting Components
Desk stand
61.6 cm x 35.6 cm x 57.5 cm
Adjustments
Tilt
13.6 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-50"
Max Load Weight
68 kg
Material
Steel
Black graphite laminate
5 years warranty
61.6 cm
35.6 cm
57.5 cm
13.6 kg
Material
Steel
AV Furniture
Mounting component
Mounting Components
Desk stand
Recommended Use
LCD / plasma panel
32"-50"
Adjustments
Tilt
Max Load Weight
68 kg
Scratch-resistant, swivel adjustment
Limited warranty - 5 years
Scroll to top
