BT.com
Wishlist
Peerless-AV Internal Joist Mount for 16'' or 20'' Centers
Peerless-AV Internal Joist Mount...
£75.70
£75.70
Add to wishlist
Delivery
Standard Due date unavailable
This ceiling fixture is designed for installation between two wood joists on 16" to 20" centers. The position of the threaded fitting, where the extension column attaches, is adjustable. The 1 1/2-11.5 NPS threaded fitting interfaces with Peerless Fixed Length and Adjustable Length Extension Columns. Wood screws for installation are included.
Peerless ACC 120 - mounting component
Mounting component - in-ceiling mounted, between seats
Mounting Components
Ceiling plate
3.8 kg
Max Load Weight
136 kg
Material
Steel
3.8 kg
Material
Steel
AV Furniture
Mounting component
Mounting Components
Ceiling plate
Placing / Mounting
In-ceiling mounted, between seats
Max Load Weight
136 kg
Scroll to top
