BT.com
Wishlist
Peerless-AV In-Wall Mount for 32-60" Flat Panel Displays
Peerless-AV In-Wall Mount for...
£454.30
£454.30
Add to wishlist
Delivery
Standard Due date unavailable
Maximize your flat panel experience by installing it truly flat against the wall with the industry's first universal in-wall mounting solution for up to 71" screens. Installation is quick and easy thanks to the mount's self-locating tabs that center the in-wall box snugly between standard 16" wood stud centers. View the flat panel screen in its no-profile home position, or extend the arm over 19" to watch it virtually anywhere else within the room. This mount holds screens so flat against the wall, it may even allow installations to meet ADA requirements.
Peerless In-Wall Mount IM760PU - mounting kit
Mounting kit
Mounting Components
Articulating arm, adapter plate, in-wall enclosure
78 cm x 49.3 cm x 55.5 cm
20.5 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-60"
Max Mounting Pattern Size
747 x 432 mm
Max Load Weight
90.7 kg
Material
Cold-rolled steel
High-gloss black
5 years warranty
78 cm
49.3 cm
55.5 cm
20.5 kg
Material
Cold-rolled steel
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
747 x 432 mm
32"-60"
Max Load Weight
90.7 kg
Scratch-resistant
Limited warranty - 5 years
Scroll to top
