BT.com
Wishlist
Peerless-AV Full Service Thin Video Wall Mount with Quick Release
Peerless-AV Full Service Thin Video...
£461.83
24 in stock
£461.83
Add to wishlist
Delivery
Standard 1-3 working days
The DS-VW755S slim full service video wall mount with quick release offers an easy to install and service ADA compliant solution for both landscape and portrait displays. Designed for quick service access in recessed video wall applications, the DS-VW755S provides versatility demanded by today's integrator. With the quick-release functionality, users have the ability to articulate the display from the wall by gently pressing on the front of the display. Featuring tool-less micro adjustment at eight points, the mounts can overcome uneven walls to create a seamless video wall display. To aid in set up and service, the mount extends the display from the wall in a negative tilt position, providing convenient access to the bottom of the display. In addition, reusable custom wall plate spacers eliminating the guesswork and on-site installation calculations and measurement reducing installation time and cost. With no-tool-required micro-adjustments and easy display access for quick serviceability, it's a perfect video wall mounting solution.
Peerless-AV Full Service Video Wall Mount with Quick Release DS-VW755S - wall mount
Wall mount
50.8 cm 50.8 cm
Adjustable Depth
4.8-6.7 cm
Recommended Use
Video wall
Recommended Display Size
40"-65"
Flat Panel Mount Interface
400 x 400 mm
Max Load Weight
36.4 kg
Black powder coat
5 years warranty
50.8 cm
50.8 cm
Adjustable Depth
4.8-6.7 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
Video wall
400 x 400 mm
Cable Management
Integrated cable management
40"-65"
Max Load Weight
36.4 kg
Adjustable depth, quick release
Limited warranty - 5 years
Scroll to top
