BT.com
Wishlist
Peerless-AV Flat Video Wall Mount for 40-65" Displays
Peerless-AV Flat Video Wall Mount...
£257.08
£257.08
Add to wishlist
Delivery
Standard Due date unavailable
The DS-VW665 is the latest addition to the increasing lineup of modular video wall mounts from Peerless-AV. This mount includes innovative features that simplify the installation process, such and custom wall spacers and 8 points of tool-less micro adjustment. These unique features provide seamless display alignment of small or large video wall configurations while ensuring each mount is positioned for the specific display being used. In addition, integrated cable management tie-backs and a clean profile cap off the aesthetically pleasing install.
Peerless DS-VW665 - wall mount
Wall mount
88.9 cm 50.8 cm
Adjustable Depth
7.9 -9.8 cm
12 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
40"-65"
Flat Panel Mount Interface
200 x 200 mm, 700 x 400 mm
Max Load Weight
57 kg
Black powder coat
88.9 cm
50.8 cm
Adjustable Depth
7.9 -9.8 cm
12 kg
Black powder coat
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
Cable Management
Integrated cable management
40"-65"
Max Load Weight
57 kg
Adjustable depth, security screws
Scroll to top
