BT.com
Wishlist
Peerless-AV Flat Panel Video Conferencing Cart
Peerless-AV Flat Panel Video...
£1,533.19
Hurry, only 1 left in stock!
£1,533.19
Add to wishlist
Delivery
Standard 1-3 working days
The SR555E SmartMount video conferencing cart offers an array of features perfect for any setting where telecommunication is required. The mobility of the cart eliminates the need for multiple video conferencing systems, lowering your overall system cost. The structure is optimized to hold two 40"-55" displays, providing clear visibility for all participants. The camera locates anywhere above either display, for near perfect eye contact during your meetings. A lockable storage area houses all components inside the enclosure and the upper door doubles as a laptop workstation when needed.
Peerless-AV SmartMount SR555E - cart
Cart - lockable
178.4 cm x 73.7 cm x 198.3 cm
Adjustments
Yaw
81.8 kg
Recommended Use
2 LCD / plasma panels / video conferencing system
Recommended Display Size
40"-55"
Flat Panel Mount Interface
200 x 200 mm, 400 x 400 mm
Max Load Weight
86.2 kg
Textured black powder
Wheels Qty
4
5 years warranty
178.4 cm
73.7 cm
198.3 cm
81.8 kg
AV Furniture
Cart
Recommended Use
Cable Management
Integrated cable management
Lockable
40"-55"
Adjustments
Yaw
Max Load Weight
86.2 kg
Wheels Qty
4
Wheel Diameter
10.2 cm
Brakes Qty
2
Limited warranty - 5 years
Scroll to top
