BT.com
Wishlist
Peerless-AV Flat Panel Stand for 32-65" Flat Panel Displays
Peerless-AV Flat Panel Stand for...
£451.84
£451.84
Add to wishlist
Delivery
Standard 1-3 working days
The Flat Panel Stand is designed to provide ideal display viewing position, centralize audio video components and match the decorate of any environment. The full line of accessories enables each stand to be fully tailored to meet specific requirements; whether video conferencing from a boardroom or presenting on a trade show floor. And the internal cable management hides all the AV cabling, providing a clean, clutter-free look.
Peerless Flat Panel Stand SS560F - stand
Stand - floor-standing
Mounting Components
Base plate, column, VESA adapter
85.1 cm x 67.3 cm x 173.6 cm
Adjustments
Tilt
36 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-75"
Flat Panel Mount Interface
200 x 200 mm, 600 x 400 mm
Max Load Weight
68 kg
Material
Aluminium, cold-rolled steel, fused epoxy
18 years warranty
85.1 cm
67.3 cm
173.6 cm
36 kg
Material
AV Furniture
Stand
Mounting Components
Recommended Use
LCD / plasma panel
Placing / Mounting
Floor-standing
Cable Management
Integrated cable management
32"-75"
Adjustments
Tilt
Max Load Weight
68 kg
Adjustable height, anti-theft
Limited warranty - 18 years
Scroll to top
