BT.com
Wishlist
Peerless-AV Flat Panel Mount  Dual Pole for Modular Series Flat
Peerless-AV Flat Panel Mount Dual...
£78.94
4 in stock
£78.94
Add to wishlist
Delivery
Standard 3-5 working days
With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application. The modular mount line was developed with the professional AV installer in mind. Designed around a 2" (50 mm) diameter pole, the line is ideal for projects as well as for upgrading existing installations. The MOD-FPMS2 tilt box is the perfect solution for mounting displays installed using the modular series line of mounts.
Peerless Modular Series Dual-Pole Single Display Mount - mounting component
Mounting component
Mounting Components
Pole mount, VESA adapter
26.3 cm x 10.2 cm x 24.3 cm
Tilt
5.68 kg
Recommended Use
LCD display
Recommended Display Size
46"-90"
Flat Panel Mount Interface
200 x 200 mm
Max Load Weight
96 kg
Black powder coat
5 years warranty
26.3 cm
10.2 cm
24.3 cm
5.68 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
Recommended Use
LCD display
200 x 200 mm
46"-90"
Tilt
Max Load Weight
96 kg
Limited warranty - 5 years
Scroll to top
