BT.com
Wishlist
Peerless-AV Flat Panel Display Stand For 50-71" Displays
Peerless-AV Flat Panel Display...
£939.24
£939.24
Add to wishlist
Delivery
Standard Due date unavailable
FPZ-670 is the only stand on the market that is designed to support up to two 50" to 71" screens back-to-back. It is one of the sharpest looking, most robust and functional stands ever. It is complemented by its sturdy base that provides plenty of concealed room for content drivers and surge protectors. Its internal cable management system conceals cables and cords, delivering a clean look for any application.
Peerless Flat Panel Stand FPZ-670 - stand
Stand
101 cm x 122 cm x 184 cm
88.1 kg
Recommended Use
2 LCD displays
Recommended Display Size
50" - 71"
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
181 kg
5 years warranty
101 cm
122 cm
184 cm
88.1 kg
AV Furniture
Stand
Recommended Use
2 LCD displays
50" - 71"
Max Load Weight
181 kg
Adjustable height, portrait to landscape movement
Limited warranty - 5 years
Scroll to top
