BT.com
Wishlist
Peerless-AV Desktop Swivel Mount (Top Bolt-Down) 200x100 & 200x200
Peerless-AV Desktop Swivel Mount...
£106.65
£106.65
Add to wishlist
Delivery
Standard Due date unavailable
The HP432-002 flat panel desktop swivel mount is designed as a functional and secure solution for desktop-mounted displays in hospitality applications. The mount directly bolts-down to the desktop surface for safety and security, with security screws that attach the display to the mount adaptor plate. With up to 30 degrees of swivel each direction, this mount provides a low-cost solution to fit a variety of needs and room configurations.
Peerless Desktop Swivel Mount HP432-002 - mounting kit
Mounting kit
Mounting Components
Swivel pipe, adapter plate, floor plate
22.2 cm x 10.2 cm
Adjustable Height
42.6-57.2 cm
2.72 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
26"-37"
Flat Panel Mount Interface
100 x 100 mm, 100 x 200 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
Material
Fused epoxy
Black powder coat
22.2 cm
10.2 cm
Adjustable Height
42.6-57.2 cm
2.72 kg
Material
Fused epoxy
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
26"-37"
Max Load Weight
36 kg
Adjustable height, swivel base, scratch-resistant, security screws
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: 9Z3F 034899
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£14.08
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
