BT.com
Wishlist
Peerless-AV Dedicated Flat Panel Adaptor Plate for VESA 800x400 Pattern
Peerless-AV Dedicated Flat Panel...
£91.98
£91.98
Add to wishlist
Delivery
Standard Due date unavailable
Large Flat Panel adapter plates (PLP models) are either universally compatible with most large flat panels, or uniquely compatible with one screen make or model. Peerless adapter plates for flat panels allow users to choose between Peerless' wide array of applications and accessories to mount a flat panel virtually anywhere.
Peerless PLP V8X4 - mounting component
Mounting component
Mounting Components
Adapter plate
83 cm x 1.5 cm x 43 cm
5.2 kg
Recommended Use
LCD / plasma panel
Flat Panel Mount Interface
800 x 400 mm
Peerless SP850; Full-Motion Plus Wall Mount With Vertical Adjustment PLAV60, PLAV70; SmartMount Articulating Wall Arm SA745, SA750, SA760; SmartMount Flat Panel TV Cart SR1G, SR1M; SmartMount Pull-out Swivel Mount SP850; Solid-Point PLT BLK, PS 1, PS 2; SP 850
83 cm
1.5 cm
43 cm
5.2 kg
AV Furniture
Mounting component
Mounting Components
Adapter plate
Recommended Use
LCD / plasma panel
800 x 400 mm
Peerless SP850, SP850P, SP850P-S, SP850-S , Peerless Full-Motion Plus Wall Mount With Vertical Adjustment PLAV60, PLAV60-S, PLAV70, PLAV70-S , Peerless SmartMount Articulating Wall Arm SA745P, SA745P-S, SA750P, SA750P-S, SA760P, SA760P-S , Peerless SmartMount Flat Panel TV Cart SR1G, SR1M , Peerless SmartMount Pull-out Swivel Mount SP850, SP850P, SP850P-S, SP850-S , Peerless Solid-Point PLT BLK, PS 1, PS 2 , Peerless SP 850, 850-S
Scroll to top
