BT.com
Wishlist
Peerless-AV Corner Mount with SP850-UNL for 32"-58" Displays
Peerless-AV Corner Mount with...
£454.30
£454.30
Add to wishlist
Delivery
Standard Due date unavailable
The CM850 allows screen to fit in corner where space is limited.
Peerless Flat Panel Corner Mount CM850 - mounting kit
Mounting kit
Mounting Components
Wall plate, interface plate, adapter plate, support bracket, tilt/swivel bracket
55.8 cm x 23.6 cm
Adjustable Width
93-111.3 cm
29.3 kg
Recommended Use
Flat panel
Recommended Display Size
32" - 58"
Max Load Weight
68.2 kg
5 years warranty
PanelWorx PX Series PX-3200; AKIRA SV-4201; Audiovox FPE3205, FPE4207; Daewoo DLP-32, DLP3212; LG 32PC51; Niko SV3206; Philips 52PFL7403; Pioneer PDP-4216, 42MXE10, 50MXE11; Sony KDL-52WL135; SOYO DYLT032; Syntax Olevia LT37; TECO TA3796; Toshiba 32A3002, 32AV500, 32AV505, 32HLX95, 37HL86, 42C3500
55.8 cm
23.6 cm
Adjustable Width
93-111.3 cm
29.3 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
32" - 58"
Adjustments
Tilt
Max Load Weight
68.2 kg
Rotating, swivel adjustment
Limited warranty - 5 years
PanelWorx PX Series PX-3200 , AKIRA SV-4201H , Audiovox FPE3205, FPE4207HR , Daewoo DLP3212, DLP-32D3 , Daewoo DSP 4210GM , LG 32PC51 , Niko SV3206 , Philips 52PFL7403D , Pioneer PDP-4216HD, 42MXE10, 502MXE, 50MXE11 , Sony KDL-52WL135 , SOYO DYLT032D , Syntax Olevia LT37HVE , TECO TA3796RV , Toshiba 32A3002P, 32AV500P, 32AV500PG, 32AV500U, 32AV505D, 32AV505DB, 32AV505DG, 32HLX95, 37HL86, 42C3500P , ViewSonic NextVision N3200w , Zenith P42W22B
Scroll to top
