BT.com
Wishlist
Peerless-AV Corner Bracket (Without Mount) up to 79kg - Black
Peerless-AV Corner Bracket (Without...
£182.83
£182.83
Add to wishlist
Delivery
Standard Due date unavailable
The CM850 allows screen to fit in corner where space is limited.
Peerless Flat Panel Corner Mount CM50 - mounting kit
Mounting kit - inside wall corner
Mounting Components
2 wall plates, 2 screen attachment plates, 4 support brackets
111.3 cm x 55.8 cm x 23.6 cm
11.7 kg
Recommended Use
Flat panel
Recommended Display Size
32"-50"
Max Load Weight
79.3 kg
Material
Fused epoxy
5 years warranty
OneMount Flat Panel Modular Wall Mount ONE-TP; PARAMOUNT Universal Flat Wall Mount PF640, PF650; PARAMOUNT Universal Tilt Wall Mount PT640, PT650; SmartMount Universal Flat Wall Mount SF640, SF650; SmartMount Universal Tilt Wall Mount ST640, ST650
111.3 cm
55.8 cm
23.6 cm
11.7 kg
Material
Fused epoxy
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Inside wall corner
32"-50"
Max Load Weight
79.3 kg
Scratch-resistant
Limited warranty - 5 years
Peerless OneMount Flat Panel Modular Wall Mount ONE-TP , Peerless PARAMOUNT Universal Flat Wall Mount PF640, PF650 , Peerless PARAMOUNT Universal Tilt Wall Mount PT640, PT650 , Peerless SmartMount Universal Flat Wall Mount SF640, SF650 , Peerless SmartMount Universal Tilt Wall Mount ST640, ST650
Scroll to top
