BT.com
Wishlist
Peerless-AV Articulating Wall-Mount for 32" - 65" Screens
Peerless-AV Articulating Wall-Mount...
£109.57
5 in stock
£109.57
Add to wishlist
Delivery
Standard 3-5 working days
Delivering excellent strength and durability, this articulating wall mount supports flat panel TVs from 37" to 56". Its smooth motion, extensive reach, swivel capabilities and tilt adjustment deliver ideal TV placement for perfect viewing from anywhere in the room.
Peerless Tru Vue TRA765 - wall mount
Wall mount
Tilt
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-65"
Flat Panel Mount Interface
600 x 400 mm
Max Load Weight
48 kg
Matte black
5 years warranty
Matte black
AV Furniture
Wall mount
Mounting Components
Articulating wall mount
Recommended Use
LCD / plasma panel
600 x 400 mm
32"-65"
Tilt
Max Load Weight
48 kg
Swivel adjustment, Hook-and-Hang
Limited warranty - 5 years
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer Return - Item has been opened but in excellent condition.
Ref: BBLH 035496
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£20.24
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
