BT.com
Wishlist
Peerless-AV Articulating Arm Desktop Mount for 12-30" Displays
Peerless-AV Articulating Arm...
£102.84
23 in stock
£102.84
Add to wishlist
Delivery
Standard 1-3 working days
The 620A series is a single display mount with a flexible arm that increases productivity by freeing up desk space with more efficient display positioning. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of the display by raising or lowering it 12.6", extending up to 22", and tilting forward and back. Furthermore, the LCW620A can pan and rotate for comfortable portrait or landscape viewing.
Peerless 620A Series Wall Mount LCW620A - wall mount
Wall mount
Tilt
Pan
Recommended Use
LCD display
Recommended Display Size
19"-30"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
AV Furniture
Wall mount
Mounting Components
Articulating arm, wall mount
Recommended Use
LCD display
Cable Management
Integrated cable management
19"-30"
Tilt
Pan
Max Load Weight
9 kg
Adjustable height, rotating, portrait to landscape movement, swivel adjustment
Scroll to top
